So, no one has mentioned it yet as such, but you have a lot of fuselage out ahead of that wing, and the sides are very flat. Basically, the fuselage is acting like a big vertical stabilizer out in front of the plane. As soon as there was airspeed enough a little bit of yaw would build air pressure on the side of the fuselage and push it further off course. Some of those really long racers from the 30's like the Caudron, Goon and Firecracker had big slab sided cowlings way ahead of the wing and they could suffer "rudder lock." Basically, if they yawed far enough the rudder became ineffective and couldn't push the nose back straight ahead.
I surmise that when you couple that with the short tail of your aircraft which limits the effectiveness of the rudder, and the big flat fuselage blanking out the left v-stab.... you get the results seen above.
Edit: Also those are some unnecessarily thick control surfaces and that's a lot of plywood in the structure. Plywood add quite a bit of weight for little extra strength compared to balsa. I don't think it factored into this crash, but it for a competition aircraft I would think weight savings of any kind would generally be beneficial.
