Thanks everyone! To be fair, there is a reason why I take the pics from a little distance away...
...they are not quite as pretty up close.
can you share some close ups and info on what you did there?
Sure. Here is a close up of the canopy.
There were a couple of things with the original plans that I wanted to modify (typical scratch builder, if you gave me plans for a 6 inch square piece of foam I would probably modify it!). Mostly I wanted to avoid the formers approach for the fuse. I never seem to get these and the poster board just the way I want them. So I imported the original SVG files into Blender, exported them from there to Collada files, and imported them into Sketchup. I could then use the original formers from the plans to model a fuse in foamboard.
While I had that done, I also tried to model in the canopy. The rear part of the canopy fit okay with a lot of bevelling to match the decking curves. The front was a disaster, so I resorted to making a screen from some thin flat plastic. Then I painted her up, masking the screen. I didn't realize at the time that when you looked through the screen, the interior would be pure white. I added some metal tape strips as additional "windows" on the canopy.
Are you going to hold off on the maiden for FFW?
I'm in a bit of a quandry over this. I don't really want to wait until FFW to maiden as I would prefer to have some time to trim and tweak if I need to. On the other hand, there is a strong possibility that I will maiden her this weekend and trash the plane. On top of that, DamoRC Jnr, who is officially entered as the pilot and who also takes all the videos, is away this weekend. So he won't have time to fly her until next week.
All that being said, these are first world problems. So I'll probably chuck her up this weekend.
DamoRC
