Build Instructions Continued
Time for a packing tape hinge to put the rudder in the vertical stabilizer
Bevel the leading edge of the horizontal stabilizer, and clear out the gutter for the bamboo skewer reinforcement.
Cut the elevator halves out before folding and gluing the horizontal stab together.
Glue and fold the horizontal stab together and bevel the bottom front edge of the elevator pieces so they will move freely when attached.
I'm still thinking about various control rod ideas for the elevator, so I'm going to set this aside and work on the fuse next.
Glue in the fuselage side doublers over the wing saddle. Make sure to align the notch in the side doubler to the notch in the top plate so it will all fold over into itself. In future plan versions I'll add some dotted line printing to ensure this part goes in the right place.
Then remember the table is your friend - but get a right angle or square too - and do a B style joint on the fuse sides, where the side of the fuse sits beside the top plate.
Stand up the other side of the fuse, again being careful to be square with the alignment. Then bend in and glue the front part of the fuselage sides to line up with the sides of the nose.
And align and glue in the tail sides too.
And finally measure up your motor mount, install some blind or T nuts in the firewall, and then glue the firewall into the fuselage. I like using white gorilla glue for this so it foams up and holds onto more of the foam that just the narrow joint. It's helpful to use a couple dots of hot glue to hold it in place for the gorilla glue to foam up and dry without pushing the firewall out of alignment.
Now to the wings. Clear out the gutter and glue in the bamboo reinforcements in the wing tips - another great place for white gorilla glue with a strip of packing tape laid over the top to prevent it from foaming over.
Clear out the gutter for the plywood wing spar and the rectangle areas for the foam wing spar alignment tabs. Also bend the wing backwards and put in the bevel on both sides of the leading edge.
Fold and glue in the wing spars, being careful to keep the gutter space for the plywood spar free and clear. Then install the servos, servo wire extensions as needed, and tack glue in the wires so they don't move around during the main fold and glue step.
