bstanley72
Is this in place of the polycrylic? Or used as a finishing coat?
I'm thinking of glassing a more complex fuselage, like the Sea Duck I want to make next. I want to glass the fuselage after assembly so it seals the whole thing from water (no seams). Question about the paper: would I assemble it first, then remove external paper and glass it?
I'm thinking of doing the same thing with my PBY but I'd prefer to leave the paper on. Removing it would not work out well for structural integrity. The duck may be the same.
I'm afraid that covering all my curves and such might not be possible, and am wondering if I could accomplish something similar by coating the competed plane with an epoxy/BP mixture without fiber sheets.
The planes to fly - Maybe?
Maybe I didn't get the question??? Are you wanting to leave the paper on? There is very little to gain by adding polycrylic or epoxy to the bare foam... very weak, but adds a smooth surface.
Using fiberglass cloth is pretty easy, and the lighter weight cloth (0.65 to 0.73 oz/yd) contours pretty nicely. Heavier weight cloth has a tendency to lay flat so tight corners and compound curves are hard to do without relief cuts.
My first planes skinned in fiberglass were done by building the plane, removing the paper and then adding fiberglass cloth and resin. I'm now skinning whole sheets of foam and then cutting and building.
David's going to build them for us too? But.... but... that'll be like keeping all the fun for himself!
Loved meeting you David, for the first time... although, I do find it funny we both live about 45 minutes to an hour from each other, yet we drive 10+ hours to Ohio to meet up. We're a bit off, eh?
Yeah, I'm wanting to leave the paper on, as removing it would destroy the plane, and fiber-glassing beforehand would probably end badly with the way some of my curves run. The air frame is quite strong as is, mostly I'm wanting to glass it so that I can get a smooth even surface, fill seems, etc. Essentially I want a good bondo for airplanes, and it would be great if it added a bit of exterior hardness to protect against hanger rash.Maybe kevlar fiber or similar mixed into the goop.
This will also be over the top of water resistant foamboard, as it seems much less likely to peel away than redi-board if it's floating on the water. Ross foamboard would be an option if the paper wasn't so hard to remove. It can be done, but it's hard to get a good curve afterward.
I think I just need to do some testing. I'll probably build a set of floats, and then try a few different coatings, and maybe even see what I can do with actual fiberglass sheets.
Hi localfiend,
I think it is going to be hard coming up with a "bondo" that is clear to use for smoothing surfaces. To smooth things out before paint, I use Q beads and epoxy which makes a white paste. This will cover your paper so I don't think it is an option for you. Maybe someone else has a better option than painting several layers of polycrylic.
If you're going to put kevlar or glass into the mix, it is my advice to just get a really light fiberglass cloth and skin the plane. I us 0.73 oz/yd cloth (Thayercraft) and epoxy resin (The stuff I use is totally clear) and with a little sanding with some 600 grit paper, it will be smooth! I just discovered the best (so far) outlet for epoxy resin - check out Resin Research and get the Kwik Kick. It is so clear that a few coats will not be seen, but each coat adds weight, of course.
I've gotten some really nice gentle curves using foam that is fiberglassed on one side. You can actually roll it into a tube if you want to. Floats would be a really good thing to practice with. Glass one side of the foam, cut out the parts, glue together and then glass the seams. I think you'll be surprised how easy and gratifying it is.
I used to live in Pullman, we could have built together,...
Yes - I thought that was your goal and yes, it will work very nicely. Peel the foam board paper, adhere the printed paper with decals, panel lines and rivits, overlay with fiberglass and build away.I don't need the coating to be clear, as I'll be painting after the fiberglass, that's one of the goals. Clear would be cool if it would work over the top of decals/skins. Is that what you were thinking I was after?
For a point of reference, removing paper and skinning with 0.75 oz/yd glass comes in lighter than leaving the paper on. If you're after structure, using 1.42 or 3.22 oz/yd cloth will do nicely but are a bit heavier than the paper. Oh, and I note that once epoxy resin is applied (penetrates) to paper, it becomes waterproof. I have tissue covered wings overlaid with fiberglass and they are tougher than nails.My fiberglass musings are directed mostly towards a large 100" PBY. I can add a lot of weight to the design before it becomes detrimental. Actually, as the design stands, it's probably a bit too light. More wind penetration would be good.
I'll order some stuff and start playing with it. Didn't realize fiberglass would bend, guess I'll see how far I can push it. Wonder if you could cut the foamboard with a CNC after fiberglass had been applied... That's the other thing I'm after, speed and quality. If I can coat a quick easy to build foamboard plane with something that makes it stronger, and smooth for paint, without adding significantly to build time, I'll declare victory.
......check out Resin Research and get the Kwik Kick. It is so clear that a few coats will not be seen, but each coat adds weight, of course...
When I do use epoxy, I use Fibreglast and it will break if you try to bend it. The stuff is crazy strong.
