Hi, I'd like to get myself a balsa plane that'd be easy to fly. I only had one plane(FT scout) and one glider in the past. And I found
this balsa kit on hobbyking. Is it fliable for a beginner ? If not do you have any recommendations for any kits ?
If you are looking for a first Balsa build, the normal Stick 40, Kadet, Avistar, etc. are all great trainers. If you really want a cub, then I'd recommend the SIG Cub over the Hobbyking one, from what I've heard. What I've been told is the Hobbyking kits can be harder to get parts for, and instructions can be hard. If you get a Cub, it needs rudder to fly, and the FT Simple Cub is a good Cub to teach that on, and is a high wing. That'll teach you how to fly most 40 sized trainers. However, both of these are relatively large, and I think a 1500mm build is better for a first balsa plane, not too small, so it flies well and any extra glue usage (which is to be expected from a first build) won't make it too heavy. 1800mm planes can be a little less maneuverable, and unweildy. You can also get a smaller Balsa kit if you are more conservative with the CA, but I wouldn't go too small. I've also looked on ebay, and this may be a good kit too. It's similar to a Telemaster, which is a great plane, I have a mini telemaster and it flies easier than the Simple Scout IMO. This plane is about the same size as my mini telemaster, 1meter, so it is a little more vulnerable to wind than the 1.5meter trainers I listed before. The Mini Telemaster I have is kind of fragile, after on unfortunate crash where the wheel caught a rutt it cartwheeled and now I have to replace several parts. The HERR Cloud Ranger appears to have a simplified construction and looks more durable. It looks nice, and I may get one myself soon. Plus, it has a long nose so any extra glue weight is easy to cancel out by shifting the battery. The bigest benifit I see in the Cloud Ranger is the simplicity and low cost. It should use a motor about the size of the power pack B, but with an 8 inch slow fly prop.
https://www.ebay.com/itm/HERR-Cloud...731407&hash=item441d437081:g:UDoAAOSwZVJa63Mn
As for covering, I like Ultracote over Monokote, but both work well for their price. A perk of Ultracote is that it smells less, which isn't much of a perk. If you plan on crashing, I'd get ultra trim as well, which is ultracote that is sticky before being heated, that way patching is easier.
