Hi all,
I had a weird idea to make a plane that could drop fire retardant ( like baking soda) or water to put out small fires (not real fires just something like a few pieces of paper inside a trash can). I have thought of a couple of way to do this, one of them being to have a water bottle with a hole at the bottom that basically drops the fire retardant out the bottom of the plane when a servo pushes something like bomb bay doors open. The other is far more complicated but seems interesting to me. I would have a canister of pressurized air that fed into a small tube, this tube would lead through the fire retardant (in the water bottle) and would then go out the back of the aircraft. When a servo presses on the pressurized air canister "trigger" the air would shoot through the tube and would push the fire retardant out the back of the aircraft. Is this even possible? I don't really know but I am interested to find out. It would be a four engine prop plane. I have never used four motors on an aircraft and don't know how to wire it. Does one of you know if it is possible to use one battery for four motors? I would love to see other people do something similar so in that sense this is a build challenge, but i understand if you already have to much on your plate and just want to watch. Any ideas/advice is very appreciated regardless of how weird it might seem. Thank you for your time.
