Some background...
I hadn't touched RC since I was a kid and had never built anything like a quad. I got a silly micro quad for Christmas, became addicted to racing quad youtube videos, bought a hubsan x4 h107d, and confirmed that I had to spend the next 4 months working part time and doing research to save up and build my first fpv quad. Here's a link to one of my FliteTest research/question posts. Thanks to everyone who helped guide me, particularly Flat4 who had lots of good advice.
My research informs me that this build would be considered a "tank". The frame is robust 4mm CF through the arms which form the bottom plate. She's also heavy. My impression is that she will do well cruising fast. Maybe others can comment once I've get more videos up. Here's a 10 second teaser from Flight 4.
Build time ~30 hours. Lots of youtube videos, guides, manuals, and some nights I didn't even touch the quad I spent so long trying to figure out how to connect parts together. (Thanks PGorey for letting me build in his garage, often until 4am).
Final (major) Parts List
Current weight without a battery or HD cam: 447g.
The Yi and printed mount will add about 100g, and my batteries are 171/224/237g (1600/1800/2200), so I'll be well into 700g+.
Flight time is 2-3 minutes with a fair number of punch outs. I've only flown big floaty turns and fast straight aways.
My research/purchasing spreadsheet has a more complete list with all the accessories I thought I would need. I didn't have to buy anything extra so I covered my bases pretty thoroughly. It also has prices and other notes I kept record of.
Pre-maiden flight (which was a success).
Parts
ESC's and motors on
Evidence of my noob 2 am soldering iron mistake
PDB and pololu 5v step down
Made some wiring harnesses, starting to figure out what goes where
First boot up with FC
Non-fpv ready to fly
Armattan LED's installed, figuring out FPV
Ended up resoldering all the ESC's into the top of the FC (which is now sandwiched on top of PDB as the FC is "upside down."
FPV testing
She's ready...
I played with wire management, this is how things currently look. Be aware the liquid electrical tape reflection looks like bare wire - it's not bare wire.
- taranis x9d plus
- ARMATTAN F 1 6
- Armattan mini pdb
- X4R-SB
- dys xm20a mini esc
- DYS MR 2306 2100 kv
- sp racing f3 acro
- minimosd
- RTF LC-FILTER (3AMP 2-4S)
- pololu 1amp
- piezo 5v buzzer
- king kong 6045
- hs1177
- fx799t 600mw
- xiaomi yi
- quanam v2 pro
- fr632 diversity 40 ch
- fatshark dom v3
- nexwave raceband 32 ch
- aomway pair
- VAS 3 turn helical
- mad mushroom
- zippy 2s 1800 mah 40C for backup fpv
- low voltage alarm
- SMC true spec 1800 mah 51 A x2
- Bonka 2200mah 55C x1
- Bonka 1600mah 65C x1
- WS2812B 5050 RGB Waterproof IP67 LEDs
- 10cm SMA Male Plug to SMA Female Jack Bulkhead Right Angle Pigtail Cable RG316
Parts
ESC's and motors on
FPV testing
She's ready...
