First Ever RC build. FliteTest Dragonfly. pics and couple ??
2manyhobbyz
First off, Hi everyone. Im a first time RC builder (although I think I have read everything and watched every video on FliteTest at least once). I am a maker so i enjoy this sort of stuff. I finished my Dragonfly about two weeks ago. The first iteration lacked sufficient landing gear for my "hard landings" (aka soft crashes.) My kit did not come with the delron landing gear and I liked the prototype gear Josh was running on his Dragonfly so i tried to copy it...poorly
After really scouring the videos for the Tough Tilt and Dragonfly builds I came up with a similar design to what their landing gear looked like but shortened the front boom arms and instead used the FliteTest cameral mount tray. All of FliteTest's gear was very high quality and has survived a number of crashes.
This is the re-designed and re-built landing gear and added the GPS. IMG_1374.jpg IMG_1375.jpg IMG_1376.jpg IMG_1377.jpg
Here is my setup. I am using HK Pilot 2.7 with Quantum LEA-6H GPS and compass, 5 MultiStar 2212 920Kv motors swinging 9 inch props but will be changing to 10 inch props shortly. Afro 30A ESCs. The system has been set up in APM Planner 2.0 on my Macbook. I'm using a Spektrum DX6 receiver. So far getting about 10-12 minutes out of a 3000 mAh 4S (with about 20-25% of battery life remaining least the Swede kick my tricopter butt.) Man, I miss seeing David on the FT videos (sigh)...
So for the questions. I am clueless on the PID configurations and i'm pretty sure therein lies the answer but when I try to do a fast, strait down decent (greater than ~3 m/s)it gets very wobbly primarily on the roll axis (pitch and yaw seem unaffected). If i do a slow decent (in the 1 m/s range) it is fine. This problem also occurs when I switch into the RTH mode. It seems to battle itself in the roll, and in this scenario mild pitch wobbles, (again yaw unaffected).
Any help would be appreciated. I will try to capture some video tomorrow or Tuesday to show what I mean.
Does anyone have PID settings for this setup yet? I'm still so new that I really don't want to go messing with all those parameters. For the time being as long as i take it slow its all good but as soon as I get the FPV wired in I know I am going to want to go faster and higher.
Well thanks for listening, checking out my build pics and for any advice. I've already learned so much from the FT community from the video's to the articles to the forums and on and on...
2manyhobbyz
some video
Here is a link to my youtube channel. it doesn't show the wobbles as i've described but rather just some flight time. enjoy
JumboJett
Good lookin set up. Did you ever get your problem solved? Where are you located it looks familiar? Im thinkin of doin a similar setup.
