First Heli 1983
L Edge
When helis finally became mass produced in 1983, Gorham's Cricket came on the market. Back then, with no internet, no simulator, and no instructions, and no gyro, you put it together. The engine was way underpowered, no cooling fan, you fought the rudder the minute you broke ground until you landed.
Blades were wood, fixed collective and you set blade angle with 2 adjustable wrenches and held it to learn how to track the blades.
After you learned how to hover it, next came circles and then doing transitional flight. Then came flight. All you were told by instructions is to push nose forward. What a surprise and it finally felt good to practice and land the chopper in one piece. I, as well as my son who was 12(he was a young jedi) taught me how to roll and loop it before the mechanical gyros came in. That was truly learning how to fly by the seat of your pants.
Now that is a perfectly set up heli or one crazy guy being able to let go of the radio to hold a live heli next to his head to tweak the motor tune.
Thats is truely amazing considering there was zero electronic assistance to be able to park that heli at one point in mid air and do that.
L Edge
That is Gorham's son. I wonder how many times he crashed in order to do this. In those days, if you needed parts, it would take about 1-2 weeks to get the part since hobby stores did not stockparts at all. Since the thrust/weight ratio was low, summer heat/moisture really screwed up on when and what you can do on maneuvers.
L Edge
How many broken rotor blades? I never got that far before I gave up. Apparently I can't hover.
We kept the training wheels on for a long time. That way, like doing nose in hover, saved the heli from damage. To save a heli, you always punched the throttle where a plane you usually throttle back. Otherwise the heli was a 3 lb bag of sugar as soon as wt overtakes throttle position.
My main issue was not hovering but landing. They tend to not land well when a random frog in the grass commits suicide on the tail rotor.
Two main blades, main shaft, flybar and paddles, linkages, tail boom, drive belt, tail blades shaft and gearbox, tail fin, and boom supports.
The mounted sherriff that made me set it down in the field about 30 or so yards away instead of flying it back to land didnt say a word. Just rode away like nothing happened.
I see, my throttle hand never learned to coordinate or where you flying mode 2?
I also understand flying planes screwed up my thought processes for choppers.
Back in the day you heli guys were considered super human
L Edge
Yes, we were flying mode 2. We were told that you will crash because it will screw you all up, but we just ignored that. Here is what a early programmed radio looks like. All you could do is fiddle with the pots and switches.
What was really scary, is the gear/INVERT switch. You did a half loop and hit the switch which allow you to fly upside down.
If you look closely, you can see the gear/invert switch.
What's the radio; Graupner? Back in 83, 'Muricans didn't have this available that I know of or if we did, it was ££££££. I'm even more jealous.
I do recall a scale guy rolling a hiller at an airshow then the actual hiller pilot saying hold my beer....
F106DeltaDart
Wow! That is seriously awesome. Flying without a tail gyro takes some serious skill! With fixed pitch, I'd be worried about an engine failure all the time. Not much of a chance to recover RPM without changing pitch!
L Edge
It was a later version (JR by circus-circus) when we were sposored doing and using collective pitch as well as using mechanical gyros. Ended up using Excell choppers in competition.
L Edge
Your right about engine failure or running out of nitro, so you very much paid attention to time element of flight.
Although complex, not to many parts you couldn't fix. Main shafts, I had a machinist drill out a junk piece of 1" steel that was shaft dia plus 2 mills and I would hammer the bent shaft thru and it would come out straight. Tail was alum so you rebent it. Gear, you made a bunch of spares.
The way I explained flying a cricket, was you have a 6" square piece of glass in your hand and someone places a marble in the center, tells you to walk and keep the marble on the glass as you walk.
By the way, I see you did an XC-142, see What I am exporing on my thread.
You had circus-circus the casino Hobby shop? That was the best hobby shop I ever saw for rich bored people. Bought a bunch of foamie .049 warbirds
L Edge
We were laughed at initially, but it was when we switched to pylon racing and Formula 1's, the equipment never failed and others began to notice it. Since my son was a joung jedi, we always had their backing in equipment from them.
boogieloo
That's great. He looks like a master pilot. I remember the gas engines on the airplanes. That was the only ones they had in the 1990s. Although I did scratch that program. But I'm starting on the electronic motors, so I hope this turns out great. I'm sorry, but was that you the pilot? The helicopters were the hardest ones to make. If you made it different or under or over weight, it could blow up because of wrong air-fuel mixture going into the gas engine. Really... And the Futaba transmitter in the 1990s were that radio. A huge antenna. They worked great because the factory settings were automatic. Not sure afterwards though. I think if I continued, same today. Just need a new receiver.
Still on it. On flying an airplane. But I had an RC race car to drive when I was a young kid in the 1970s. It was the one from radio shack. The workers put the RC race car together for us when we were a kid. That was the whole thing. it. So not that much hobby to that. I think once I get a handle on the FlySky transmitter and how it really operates, nothing to it to building one more airplane that works. I think it is just physics to that is important to know. You know, finding the right battery. The batteries then for the RC cars were factory made. I think Lithium batteries. Now they cannot be mixed, so not sure if Lithium battery is used for RC cars. They only use Lipo batteries now.
