First Home-made Quad, but it keeps flipping on takeoff
Flyerminer
I've checked the prop direction, Calibrated the ESC's, even set the trim to the opposite direction. Nothing seems to help :( . I'm using the Flite Test Electrohub build kit, using a standard X-configuration. I think its something wrong with the programming maybe but I'm unsure. I'm using a Multiwii Flip 1.5 control board.
The code used is in the link below:
Download of Code (zipped File)
I realize that is a lot to look at, but I really am in need of help. This quadcopter will not lift off unless I can correct this problem. :( :confused::confused:
If it isn't a question of coding, this is a picture of the quadcopter itself:
http://i.imgur.com/eQzkf1l.jpg
http://i.imgur.com/ejsN46z.jpg
I'm using the following specs:
Electrohub Frame
Tiny Titan x2212 980kv motors
Lemonrx featherlight reciever
F-20A Fire Red ESC's with SimonK firmware
9x4.5mm props
Turnigy 2200 mAh 3S Lipo Battery
Please, anybody who can help, I really need it
jipp
hi, you say you checked the props.. do you mean you checked to make sure they are point the correct direction? the text on the prop faces up.
the next thing that comes to my mind is double check to make sure you motors are spinning in the right direction.
its all that comes to my mind at the moment.
chris.
Flyerminer
chris.
I have checked prop direction, no problems there. Text on prop is facing up as well, but that's a good tip.
Motors are also spinning in the correct directions, top left going clockwise, top right going counterclockwise, bottom left going counterclockwise, and bottom right going clockwise.
Flyerminer
So after checking my quadcopter's motor power in the Multiwiiconf GUI I'm noticing something really strange.
The rear left and front right motors seem to continue increasing power after I stop moving the throttle. And on top of that, they're not increasing equally. Each increases at its own rate it seems.
Any Idea what is going on? Despite seeing this I really have no idea why its doing it or how to fix it.
JohnRambozo
I didn't see you mention calibrating the board. Make sure its perfectly level on a surface that won't vibrate and calibrate the board, otherwise it wont know which way is up.
If you did that already, is there any chance you have the motor wires swapped at the control board or rotated? What about a possible short at the esc connection to the electrohub? If everything is hooked up correctly, it could be a bad esc (or miscalibrated esc)... even possibly a bad motor? Try running through the ESC calibration again.
I'd also double and triple check the connections to make sure the motors are in the right places and the control board is connected to the receiver properly.
What software are you using to set up the flight control board?
And I'm sure you have, but just make sure you run through the full setup, step by step:
http://www.hobbyking.com/hobbyking/store/uploads/463565377X19082X13.pdf
Also! :) It seems this has been a problem for others using the same control board. Try reading through the suggestions here regarding minthrottle settings: http://forum.flitetest.com/showthread.php?13598-My-ESCs-and-Multiwii-Stink
Especially this from Joshua Bardwell:
If your motors are not starting at the same time, but still start up one at a time while at low throttle, and you've already run the ESC calibration sequences, you need to increase the MINTHROTTLE setting in the config.h file and upload. If you switch to the naze, you'll likely still have to adjust this, but you can do it from the CLI interface instead of opening the source code and rebuilding.
FYI, changing this value in config.h does nothing on my MW Flip 1.5 with MW 2.3. In MultiWiiConf, in the upper left, if you click "Settings", you can change MINTHROTTLE on that screen, and it appears to work.
Something else that is important and this probably should have been first (thanks again joshuabardwell in the above thread): Are you troubleshooting in ACRO mode? That way the board isn't trying to autolevel and spinning the motors at different speeds.
NuttyGeezer
Mine kept flipping with a kk mini board because I had got the motor layout wrong, so the motor it though was on the left was actually on the right, so when it tipped slightly it would throttle up the motor to try and level, instead making the quadcopter tilt more. Check the motor layout and make sure the ESCs are plugged in to the right places on the flight controller
Also prop measurements are in inches, not millimetres, it was probably just a typo but I'll tell you anyway
JohnRambozo
That's honestly my best guess. Let us know!
Flyerminer
I'm back! okay so I tested each speed controller individually by attaching it to the receiver, eliminating the communication of the board. Each speed controller is in good shape, none of them continue to accelerate past what I told it to, so thats good.
This leads me to believe its a problem in the programming of the multiwii flip 1.5, but I'm not entirely certain on how to fix that. I've tried uploading the default configuration for an X quad, only changing the minimum value for the speed controllers, knowing that the simonK firmware on the speed controllers are supposed to be lower. They still seem to accelerate. Is this a problem with configuration and programming or is it a problem with the control board itself?
I have made sure each motor is plugged into the proper location, front left D3, front right D10, back left D11, back right D9.
Snarls
Gravity Tester
Is it flipping when I just starts to get lift, but is still on the ground, or is it flipping in midair as soon as you take off. With multiwii boards in my experience the quad may tilt a little while lifting off and you have to input against it at least until all feet are off the ground. Then it will be stable. So have you tried controlling against the flip until it is in the air? Are you flying in autolevel? If so it is normal to see that overtime the motors will continue to ramp up because they are trying to level the quad, even though unlevel ground is preventing them from doing that.
Board orientation looks good, props look good, and motor plug location looks good as well.
Flyerminer
That did it! I lifted it off the ground quickly instead of a slow liftoff, and once it was in the air all was well! Thank you so much! odd that it does that much to autocorrect it, and that the readings were so funky in the gui. thank you! :D :D :applause:
jipp
its good to hear you figured it out.. now go break some props.. you did buy lots of extra yeah :d
chris.
Snarls
Gravity Tester
Glad to hear you got it flying! Taking off will be easier every time you do it. Another thing is that as you tune and get closer to the best PIDs for your quad you should feel it behaving nicer on take off. Now go out and fly and release your frustrations! :)
