I live in Australia so would it end up being pretty expensive to go for the ft flyer as I would have to pay for the shipping as well as the kit, the electronics, the batteries and a transmitter ?
I learned on the Champ, and it is great until you crash it. Repairs are relatively expensive (10 dollars for a replacement tail) and rather common.
I've heard that the Duet is a nice trainer; check out this video: https://www.youtube.com/watch?v=LTXL_YXjHk0
If you can, go the FT swappable route. It is rediculously cheap to proceed once you get going, and a repair to a plane usually costs less than a buck. I went straight to the FT Flyer and Nutball after the Champ, and it was great. But be warned, it is a bit costly to get going along the scratch build route buying all the electronics and such, so a cheap RTF from Horizon might be the best way to go for a complete beginner.
Also forget about buying anything locally; Australian hobby store prices are generally about triple what you'll pay at Hobby King, even after shipping.
Fortunately, FT plans are free to download and Hobby King sells packs of 5mm Depron that work perfectly well for FT foamies when coated in Minwax and butcher's paper. You'll probably get a few cosmetic wrinkles in the paper, but they don't notably affect performance:
From Hobby King, in Australian dollars, you're looking at:
Turnigy i6 (which is actually a rebadged FlySky, IIRC) with a matching 6-channel receiver. Fully programmable digital radio with all the tricks, $70. About $350 if you buy it locally.
Servos are about $5 each (again, Hobby King; $20+ locally), brand doesn't really matter. Motors are around $20 and a speed controller is $15 or so. About $10 for a battery, $30 for a charger and you're set.
Crashes only break foam (almost always repairable with hot glue, about $2 of foam if you rebuild from scratch) and occasionally props ($2 from HK, $8 local). The electronics just get swapped from plane to plane.
Shipping is generally $10-$30, depending on how much you order. Make sure you select the Australian warehouse when you're browsing their site; try to make one big order instead of lots of little ones if you want to save on shipping.
A great starter plane is the HobbyZone Sportsman S+. Though it is very expensive ($350), you get a lot with it. Believe me, it is close to uncrashable! It has virtual fence, which is really nice because it returns to you when it is out of sight. It also has AutoLand, which is awesome because landing can be quite terrifying!
"I have decided to go down the scratch building route"
I am building one of these http://newtonairlines.blogspot.co.uk/search/label/trainer as designed and built by one of your countrymen, Andrew Newton.
Further down the page, he has links and recommendations for a beginner's set-up
Good luck
For now, I'd go with the Tiny Trainer over the FT FLyer.
