how do you guys think I should put on landing gear?
oh, and is there any information of putting on control rods and horns? I don't really get how to do it..
First you turn on your Tx, and plug your stuff in, create a new model so the trims are on 0 and the servos get centered. You can then mount the servos (not glued, just test-fit) and glue in the horns so that the holes are straight above the hingeline. Then grab piano wire and make a bend like in the Flite Test video, and insert it into the control horn. Put your control surface neutral to the wing and measure the length you need for the control rod. You can use an extra V-bend in the middle to adjust it if you get it wrong. Make the other bend where it should be. Now pull out the servo, install the rods, test it, and fix the servo into the slot.
