My son and I are in the process of building our first scratch plane - the Nutball. We ordered the parts rom HK (pretty much the exact part that were reccomended in the original nutball build video), waited and waited for them to arrive, finally got them on friday. We are now trying to test everything out but for some reason the motor will not turn.
The lipo is charged, plugged into the RX, a test servo is also plugged in and works fine. I have 2 radios and 2 receivers and have tried both. Same issue.
The motor does not beep (or is it the esc that is supposed to beep) - I have tried testing the motor output voltage at the esc but get zero volt readings across various combinations - this may be correct since this is some sort of 3 phase system.
Any suggestions? Am i doing something wrong? Is there a way to test an ESC? I only have 1 motor and 1 esc so I cannot swap out to try and find the culprit...
Any suggestions? Thanks in advance for your input.
D In Mtl
D In Mtl
