Grifflyer
WWII fanatic
Normally I don't run my wires through the hole, Instead I run around the firewall and cut a tiny notch in the fuse to make a bit or room for the wires.The evening was not wasted on my single post above. I did this:
I forget whose idea it was, but somebody mentioned they were thinking using one of these to do this:
Well, it worked! Cost me $1.59 at Walmart. That led to this:
Which led to this:
Which got repeated four times in just minutes for each. Honestly that little piece of plan was pretty much done at the end, but that's four parts out of one piece of cardstock plan. The marking took no time at all! Not bad in my book.
Then I spent the next couple hours just trying to get the new rotaries to work with the firewall. The wires are heatsinked right where they go through. I can only guess that is by design. It's an obvious stress point and an abrasion-wear point. It did make things tough though. I finally got it to work.
The PowerPods are not finished. The firewalls have not been glued in and there has been no taping done. However I have four of them. I had to widen the corner slot of the firewalls some to fit the heat-shrink on the F-Pack rotary. You can see where the The firewalls are 180 degrees opposed. That's just where the A was comfortable with the wires going through the hole.
It's a serious bend on the wires, but I think I can turn it around and build the PowerPods all the same. I've more to explore on getting the A rotary to mount on the firewall and use the corner slot instead of the hole, but I am done for the night.
Either way it's up to you.
