The only curved fuselages I have built were pretty cylindrical. Making it quite easy to wrap pieces of foam around circular formers then pinch the end of the fuselage around the vertical stab.
For forming them into a cone, there are two ways: cuts go down the fuselage longitudinally, so the flat piece ends with a set of triangles. This is easiest to do with prism fuselages that have hexagonal or octagonal cross sections. I have tried to bend the pieces of a fuselage to make the finished piece more round, but it's hard to get a piece foam to bend along the long
and lateral axis.
So, here's the other way: you connect a series of curved pieces of foam to bend into conical cylinders or half-pipes.
(These shapes are for the sloping curved front, underneath the motor)
