Greg2B
I'm starting up another build and I'm going to attempt my first tricopter. Seeing David tri is probably one of the first thing that got me thinking about multi's but the using servo's scared me since I've never even really thought about them until I got into all this.
Recently I just randomly got a servo from radio shack with the intention of testing it out and seeing if I could get it to work. Of course when I finally did test it I blew it up using the wrong voltage....
I'm going to be using the parts from my first quad the turnigy microquad so
I'm currently using a Turnigy Servo 5.5g but I also have two 9 grams as well. My micro tricopter is going to be using the BlueSkyRc Micro frame. I already painted and put the frame together.
I also went ahead and put the motor mounts on and used a rapstrap to attached the servo for testing.
Seems like everything works fine. The only issue I've notice so far is the servo arm doesn’t like staying on the servo. I'm think add some glue would solve this issue but I would hate for it to be off a bit and I need to pull it of to readjust and can't. Here is a video of me testing the servo.
This looks good right? Based on the youtube videos I've found this looks all right.
Side note I just remembered from an email today that I actually did support the pocket drone kickstarter, which should be coming soonish, since I really wanted a tricopter back then but didn't think I could build one. Sort of wish I didn't spend the money it now...but it should be another neat addition to my fleet.
- Turnigy T1811-2900kv Brushless
- Turnigy Plush 6A
- kk 2.0 flight FC
