Flashing KK2 Mini with USBASP MAC
razor02097
Rogue Drone Pilot
I believe it needs to be plugged in so the ribbon goes toward the screen. If you plug in the connector the KK2 should power on with just the USBASP device. If it does not power on you can turn the connector around.
mumbi
i tried almost every position... flashing not working :(
I read that its not working because i havent got the right pins with a 10 connector ribbon cabel - but videos show that it is working in some position. Ideas?
mumbi
Yeah it finally worked. The link of you havent worked in my case - i found these that totally worked for me!
Thank you
