Flat bottom wing spar
Plane
Hi
I justed wondered if this wing spar would work on a flat bottom wing it 6 inch along with a 1 inch height just wondered if it would work if not is there any why to approve it
Thanks for you Time and your help
d8veh
6:1 is about right, but your photo shows less than 5:1 so it looks a bit fat.
I make a 1" wide section, so that I can plan the construction:
GMalatrasi
Hi
FYI: The spar runs along the length of the wing:
What you show in this picture is a rib.
Good luck with your build!
quorneng
Your picture shows a wing rib.
It creates the wing 'section' that determine the ratio of lift and drag generated as it travels through the air.
The classic Clark Y wing section does have a flat underside over most (2/3) of the underside and has a thickness to chord ratio of 11.7 so is much thinner than the section you as showing.
A true flat bottom section is a bit less efficient and can have odd characteristics at the stall than one with a proper rounded leading edge.
In general at model sizes a thicker the section does give more lift but the drag it creates rises faster than the increase in lift so you need more power.
I hope this helps.
Plane
Rib
I hope this helps.
Thank you
Does this look more like it
