flip 1.5 problems
760flyer
I ordered a flight controller with the ft electro hub kit from rtf quads. The flip 1.5 with pre programmed quadcopter firmware won't tell the motors to give throttle (the motors won't move). I am new to multirotors and I don't know what to do help!!!
cranialrectosis
Welcome to the FliteTest forums.
More details are needed.
Have you connected the flip to a computer?
Are you running Baseflight, Cleanflight, Betaflight...?
Copter boards need to be armed. Most of us program a switch on the transmitter. Old school (and the flip 1.5 is pretty old) is to put the throttle at 0 and then full left yaw to arm. Throttle at 0 and full right yaw to disarm.
Please, do not power your copter on the bench with props on. :)
makattack
Winter is coming
The flip1.5 only can run multiwii software so that is most likely what's pre-installed. I know a lot of people who used to fly with it used spektrum rc tx/rx's and you would need to increase the channel limits in order to perform stick arming. It would be helpful to know what rc hardware you have, as cranial mentions.
TEAJR66
Flite is good
Welcome to the forums.
The flip 1.5 from RTFQ, pre-flashed, will fly out of the box without connecting to a computer. The challenge is usually in the RC Transmitter. Knowing the stick commands is a must. Then setting the endpoints for each channel.
If you have not been to this page, this might help.
https://www.dropbox.com/sh/3ptxpwesovd7tx3/gYdZU3lXQh
Any other info about your equipment will also help.
TEAJR66
Flite is good
I am not familiar with Spektrum Radios. I do not know how to set them up or program them. Sorry for my lack of help there.
Check back often. Plenty of Spektrum users here with lots of experience.
760flyer
I have a dx6e (6 channel)
PsyBorg
Wake up! Time to fly!
Red light on a receiver usually means it is not bound or has no signal. I would try rebinding the receiver again and see if you get a constant green light.
Post back here with any more details and we can go on to your original posts issue.
760flyer
I just rebound the transmitter to the receiver and when bound it the flight controller flip 1.5 was red again.
PsyBorg
Is it by chance a satellite receiver? If so they can only be bound two ways. First it has to be connected to a main receiver and bound. THEN it can be separated and used as a "Mini" receiver. The other is to go into the gui and use the bind command.
Snarls
Gravity Tester
Yes the Flip1.5 should have one red LED on when it is powered. It will then have a blue LED in addition to the red LED when it is armed. So if you are not seeing the blue LED then you are not arming.
I suspect your issue is with the endpoints of your transmitter not being enough for the board to arm. It is a common issue with Multiwii. Multiwii has two parameters to check before it arms: Mincheck and Maxcheck which are by default 1100 and 1800 as far as I can tell. That means that when you push the throttle stick down and to the right, you need the throttle channel to go below 1100 and the yaw channel above 1800. You probably don't have the GUI or want to hook up to computer to see those values, but your radio probably will show it to you. Look up how to increase the endpoints on your transmitter so that full stick deflection can produce values lower than 1100 and above 1800. Here is a video if you are interested.
Also here is a list of the multiwii firmwares should you want to play around with settings or use the GUI.
760flyer
I don't know much about multirotors, but I did try to work on the throttle and servo settings. So the board did arm but the motors would go crazy.When I tried to change the servo settings the board would not arm again.
PsyBorg
Ok so I had a reading comprehension fail.. You did say the FC had the red light.. Glad Snarls is on top of things. Sorry mate.
760flyer
YES the FC is only red.
jhitesma
Some guy in the desert
Motors going crazy is a good sign you may have a motor wired to the wrong port or going the wrong direction. Assuming you're far enough that you're trying to fly it.
If they're really going crazy then hopefully you're still testing without props :)
I haven't flown MultiWii in a few years but I'm pretty sure the default has spin when armed enabled so when you arm the motors should start spinning...but they should be spinning at your min setting - very slowly. If they're spinning faster then you probably have too high of a min setting (I forget the exact var name since it's been so long since I used MW) and need to lower that (and probably lower the range in your TX as well.)
760flyer
Beta flight will not connect to the flip 1.5. And all my motors are spinning correct I tested them one by one.(Props Off)
