Flip 1.5 will not arm
Cranial
I just received a brand new flip 1.5 with a case as a part of the electrohub kit. I have built the quad, soldered, and plugged everything in correctly. my issue is that when i turn it on and attempt to arm, nothing happens. There is no led that lights up on the board- red, blue, or otherwise. i have tested the receiver with a servo and have tested the esc's individually. I am using a DX6 also. Any input will be greatly appreciated. Thanks.
makattack
Winter is coming
Did you extend the ranges on your dx6 for roll pitch and yaw? The package recommends 130%, but if you can connect it to your computer and run multiwiiconf or multiwiigui on mobile, you will get better accuracy and control with rates that will allow you to get as close to 1000 and 2000 for pwm values on those channels.
Cranial
i have changed throws to 130%, but am yet to use the config software. how do I get the config software on a mac?
Quad
You can start with the MultiWiiConf23.zip. That should be enough to start on the arming issue.
makattack
Winter is coming
How are you trying to arm? throttle zero, full right rudder/yaw?
If your channel are +/- 130%, that should work. Did you power up the copter/board while it was still so that the gyros can initialize?
Cranial
I have looked at the throws. They are at 130% +/- and I am arming with the throttle down and the rudder full right. I've done what I can think to do to arm. When I plug the FC into the computer and power it on, it works fine. When I unplug it won't work. the LEDs work when plugged into the computer, but also go off when unplugged. Not sure what this means. I have opened the config program, but cannot see anything change on the program when I move the gimbals.
Cranial
The LEDs come on and the fc works when plugged into the computer, yet it doesn't work and the LED's go off when unplugged from the computer. I think that it is just receiving power from the computer and somehow can't from the battery, but my receiver still gets power from the battery.
jhitesma
Some guy in the desert
Yeah that sounds like a wiring issue with the board. Are you using opto ESC's maybe? Can you post a photo of the wiring?
Cranial
Im using the Simon K ESCs that come in the readytoflyquads package. I too think it is a wiring issue within the board because when powered through the USB (without the MWconfig program running), it works perfectly fine. However, when I unplug it, the LED's turn off and the board will not arm. The odd thing is that the receiver gets power. I'm thinking I may have a bad board.
jhitesma
Can you post photos of you how you have things wired? I didn't mean it sounded like an issue with the board - I meant it sounded like an issue with how things are wired to the board. Not saying it can't be the board...but it sounds more like an issue with how things going to the board are wired.
Do you have power from all of the BECs on the ESC's connected (assuming they're not OPTO ESC's)? If so that can cause problems. You should disconnect the red wire from all but one ESC so only one BEC is being used.
Cranial
I am sure they are SimonK ESC's, as they are from readytoflyquads' electrohub package. I have disconnected all red wires but one, and no LED will power on yet. I believe the receiver is plugged in correctly, because I followed the build video and plugged in according to the notations on the protective case as to what goes where. I have even unplugged all ESC's except one and still nothing. I can't find any other possible issue than the FC.
Shihido
Having similar problem with flip 1.5
Hi, I am having a similar problem with my Flip 1.5
Initially, from the maiden flight, the tricopter would spin uncontrolably; i found online that the recommended solution was to make an amendment to the firmware under config.h, which i did, and now the tail responds appropriately to yaw movements.
But now i have this problem, where the blue light blinks non-stop. I think that the FC is unable to calibrate the ACC/Gyro. And i am unable to arm the tricopter as well.
I cant seem to get the MultiWiiConf to run on my laptop.
Can anyone help please? Thanks
RichB
Post a picture of the board so we can see how you have it hooked up!
RichB
Blue light blinking means arming is disabled because you have "only arm when level" and you need to calibrate ACC for the board to know what level is.
MultiWii calibrates gyros at each startup. Accelerometers need to be calibrated manually.
If you don't have MultiWiiGUI working, you can force a ACC calibration with stick commands:
Power on copter.
Put the right stick all the way back and the left stick all the way back and to the left.
ACC calibration should begin. Release the sticks.
After a few seconds, try to arm again.
RichB
Power on copter.
Sorry, I was wrong. ACC is left stick forward and left
