FPVology: Since the fuselage was glassed with epoxy, a hot wire would never go through that. In addition, when you use a hot wire it melts away a portion of the foam. This is called "kerf." Since I wanted to use the part removed as a mold for the canopy I had to minimize this kerf as much as possible. Since I had previously hollowed out the fuselage it just made sense to use a hobby knife. First, very careful shallow cuts to penetrate the glass, followed by going all the way through to remove the canopy entirely.
I wrapped up the majority of the cockpit area. More to come when all the paint is done. I needed a back plate and decided to carry the horseshoe shape that will accentuate the instrument panel's shape. As you can see, its a very clean layout that drives focus onto the motor and ESCs separately. There will be a large hole it the back plate to vent air aft. I'll use some screen door material on the back side so that there is some material to visually segregate off the cockpit from the battery compartment. More on that later.
Because I had to... I applied some red paint to the motor compartment. I really wanted to see the contrast and get the full image of how this area will look. Pretty sure this is the final nail in the coffin for how awesome this motor is. You can also see the ply plate that I installed that the balsa ESC tray/cockpit will screw into. There is another far aft.
The new Oleo struts arrived via DHL express. These are called offset oleos for fairly obvious reasons. The wheel is offset from the oleo center line. What you see in the image is a front-view in the retracted position with the airplane inverted. So, the top of the image is the bottom of the airplane. The wing needs a filet on the top and bottom portions. If you go back and look at Post #340, you will see that the previous oleo struts forced the wheel to protrude too far through the wing. Once the wheel axle is trimmed and I do some final fitting, this will be a perfect fit and my landing gear is now a non-issue. The wheel axle will be at the scale position when down so the ground handling on my rough field remains. Perhaps we will see the new gear installed this weekend.
Lastly, more sanding and smoothing of the canopy forms. Not much to show other than spackle and WBPU is doing its job, one layer at a time. The thing any person who pulls their own canopies can tell you is that every minute of preparation of a smooth finish will greatly pay off for a perfect pull. Carl, I am sure, can attest to this.
