So, I noticed that we have a lot of terms and abbreviations (interesting word, when you think about it - it's really long, and the meaning of the word is to shorten a word!) within RC hobbies in general. I figured we should make up a list of these terms that might help newbies or people interested in the hobby to help out.
Let me start:
TX - Short for Transmitter, also referred to as your radio. This is what you use to control your aircraft, whether it's a quadcopter, plane, sailplane, etc. Some transmitters are meant for surface/RC cars and trucks, and USUALLY have a trigger control for throttle, with a steering wheel on it; the aircraft radios all use two sticks to control.
RX - Short for Receiver. This is installed in your aircraft, and is what is used to control servos or an ESC for throttle.
ESC - Electronic Speed Controller. This is what controls the throttle and gives power to the motor for your aircraft. There should be one ESC per motor.
FC - Flight Controller. Usually found on multirotor aircraft such as a quadcopter, although they are being used more often in airplanes as well. The Flight Controllers in the multirotor aircraft are GENERALLY used (and I'm simplifying this quite a bit) to help determine attitude and help keep the multirotor level. In aircraft, they are used to help give a more stable flight by making minor corrections. If you see a plane with AS3X or SAFE Select, this is a form of flight controller, using it to help fly in a stable manner.
FT - Abbreviation for FliteTest
TT - On the FliteTest forums, it refers to Tiny Trainer.
I know there are TONS more, but I'm drawing a blank. Anyone have anything they want to add, please do!
Let me start:
