Flite Test member map
eagle4
Hi Dave,
It seems I'm just down the road from you in Saint Lambert, I added a Pin, then another and one for luck. Being unfamiliar with Google Maps, I could not see the PIN I added so figured to add another...
If you have Mod access could you please delete 2 of my pins?
Regards,
Rob
Hey Rob, fantastic :) once it gets warmer we should try to fly together at some stage. my only problem is i dont have a car, so my ability to get to any flying field is a little tricky
no worries, removed your unwanted pins.
pgerts
Old age member
There seems to be quite some pilots with sea planes ;-)
The Pacific
The Atlantic
Quite some in the Mexican Gulf ;-)
xuzme720
Dedicated foam bender
Yes, it seems that, either on purpose or by accident, pins are being moved all over the place. It's too bad because this was a really good idea.
themajik1
Monkey/Bear Poker
Yes it seems that pins have moved. Good idea, too bad pins couldn't be locked so they cannot be moved. Nice thought though!
jsut210
Expert Crash-Lander
My pin either is being deleted or has never been added at all....I give up. It would be cool to find a site that allows only the edit of a set user's pins.
jsut210
Expert Crash-Lander
Huh...It seems that it was just all the way back on page 5. It's a shame that all the pages' pins are displayed individually rather than all at once. This means that you have to look through all the pages to find a local flying buddy.
rcspaceflight
creator of virtual planes
I think if you look at the map when you're not logged in, it'll show ALL of the pins. At least if you flip to the last page while not being plugged in.
eagle4
the ones in the ocean are because people move them instead of panning, its an easy mistake to make, but then they dont hit the undo button at the top to put it back where they found it. that undo button needs to be bigger
Kurt0326
Your ADD Care Bear
Map will not save.
I pined my place and it said saved to map, i reload it to check and it's not there. Help.
