Flite test swap-able flight times.
justincaligiuri
I want to but a swap-able for fpv and I want long flight times. Which swap-able with the recommended electronics will give me longest flight times.
xuzme720
Dedicated foam bender
Flight time is determined by battery size and amp draw so one that needs little power and can carry a large-ish battery would be best. The Simple Soarer could glide for most of the flight so it might be along the lines of what you're looking for.
Bayboos
I agree, among all the swappables I know, FT Simple Soarer is the best candidate for winning the logest flight duration contest.
However I did achieve some pretty impressive results on my ultralight FT Simple Storch, up to 34 minutes on 2200mAh 3S.
Also, you may want to look for flying wings with long, skinny wings; like the ones in this article: One Sheet and Two Sheet No-Waste Flying Wings (especially the two sheet versions). Those are not swappable, but there are examples on how to convert a flying wing into swappable, you should not have troubles finding one.
