Flitetest DIY Gremlins
PyroMan
I've been able to fly quite a bit over the long weekend and I love my gremlin! So much fun! I'll see if I can post video or photos when I get home from work.
I do have some questions:
- I wish my roll and/or flip rate were faster. I see like the FT guys do real quick rolls indoors. I cant do that. I don't know if it's pilot skills issue or software/roll rate issue. The way I perform a roll is by punching throttle and cutting throttle to get the quad to 'coast' upwards then full right or full left to get the quad to roll. Then increase throttle when right-side up again to catch the quad. I cant due this close to the ground cuz I need room to 'catch' the quad. It just seems the roll rate could be more snappy. I'm using stock rates in BetaFlight. never adjusted any of that. Is there something I can tweak in BF to tighten up rolls? I imagine same advice will apply to tightening up flips?
- I have one motor that is slow to spin up. All the motors will be spinning at minimum throttle setting when armed, except for one which is kinda half spinning. Kinda a spin-stop-spin slowly kinda thing. Then after a few seconds or a quick touch of throttle on or off it will smooth out to a normal spin. The quad flies fine once I get it spinning, it just seems weird. Thoughts of what might cause this?
- I've noticed the quad has to be still and in a similar orientation that it initially was powered up in to arm. I've also noticed after a tumble, it won't arm no matter the orientation until I unplug battery and let the accelerometers re calibrate and such. These issues are quite annoying. I want to flip my arm switch and the quad arm. I dont want it to worry if it's tilted 15deg to the left or if I'm holding it and it's moving around. I don't understand the post-tumble not arming thing. Maybe the accelerometers need to recalibrate after being jostled? Can I turn any of this stuff off in BF to allow arming whenever I flip my switch?
Thanks!
nevenelestate
No Agenda FPV
To get faster rolls and flips you can raise your pitch and roll RC Rates.
The not being able to ARM is most likely because you have the accelerometer turned on in BF. If you turn it off it will not require the quad to be level to ARM, but you will loose Stab and Horizon modes. The reason it needs to be level is to set the level position for those modes. Just turn it off and fly ACRO and never look back at auto-leveling.
PyroMan
Awesome! I'll definitely play with those this evening.
Yup, I only fly acro as it is. Except if I'm inside I dabble with horizon, but not much. I'll just kill it all together and go acro all the way!
PsyBorg
Wake up! Time to fly!
I get the no arm thing a lot after a crash. I just pick it up and hold it level, switch between acro and horizon mode and back again and it arms fine. Think there is something in beta flight a tad confused where it wont reset the fc in acro mode if it sits upside down more then a few seconds. That or something with the FEMTO board itself.
Try the rates I been using. Its VERY docile at center stick but will snap right over at full deflection. I fly these now on all my quads.
T-Richard
Help!
So I was ready to build my 3s gremlin and I think the baby redbottoms have a different mounting patterns!???!? they don't seem to fit
Del-Dredd
Probably the standard 1104 size 9mm spacing the Emax 1104's like in the kit are 8.5mm which I thought weird as well.
bigALUSMC
Lumenier Mini 4Power.... anyone use one of these yet? Looking to build a Gremlin using a GR18 without its plastic cover. Any thougts?
Del-Dredd
Made another Gremlin like quad 112mm using Racestar 1104 6500Kv and Mini PicoBLX stack FC and ESC with 3020 props.
Frame https://www.banggood.com/X3-EYAS-11...-Carbon-Fiber-FPV-Racing-Frame-p-1167161.html I used the 3mm Motor mount spacing is 9 and 10mm so the Emax 1104 would need it to be filed a little.
Will be 100g maybe under with camera when/if I fit it ready to fly with 520 2 cell,
just using LOS currently, it flies nice with BF 3.2
PsyBorg
Got up early this morning and it was perfect for a few flights. I grabbed my old Cannon camera and did a fast comparison of 2s and 3s using the settings I keep telling people about. This will give a much better proof then just me telling you. There is more explanation in the description for the video if you open it in YT.
TazRC
Obsession, not hobby
That's interesting, PsyBorg. Your Gremlin makes the same "sloppy bearing" noise that most folks talk about with the Babyhawk and seem to think it's from the plastic frame but this suggests otherwise.
PsyBorg
I think that is just natural resonance of the frame enhanced by not so great condition props. They are bent and rebent and chipped and dirty hehe. Motors seem nice and tight. They have always had that I have dirt stuck in me sound to them even brand new. The only time they are actually quiet is when the props are not on. Its seems louder because where I am is like an echo chamber when facing that building. Good natural reverb there
PsyBorg
Just came up with this for an answer to the noise. I will bet like me they are running multi shot. Joshua Bardwell explores the synced and un synced modes for multi shot.
I did not notice the grindy sounds but there was no prop on that motor AND it was a larger motor with much thicker bell. There is however a distinct change in motor sound when just the two sounds are isolated and put side by side. Another thing is the Gremlin frames seem to have a wider arm section for them square props to be pounding air on in relation to larger quads. On the Josh B frame they have two of those sections to beat on. That noise HAS to be transferred thru the frame between it impacting the frame then bouncing back and hitting the next wave of air from the trailing blade and so on. Some of that air is getting forced into the frame where it encounters more resistance when hitting components and that will transfer to the frame as well. I think if there was a way to adjust the gyro sensitivity on the micros or for that matter any quad we could tune that resonance out. But I think they are doing that with math in the filter algorithms instead of the physical parameters of the gyros.
JUSS10
I like Biplanes
I recently decided to jump in on the gremlin fun. Been posting a few pictures of the build to the FB group but here is my finished gremlin. I decided to design a custom 3D printed frame for it. The arms are removable and bolt on where the standoffs go that hold the top and bottom deck together. Turned out pretty good! I'm running a TX01 camera and a micro 8ch sbus receiver from banggood. This was my first time setting up beta flight and BLheli tuning. Took a little while to get it all working but once I did it flies pretty great.
SP0NZ
FT CAD Gremlin
Admin
Saw that on FB, nice looking Gremlin. Are you planning on sharing the files with the community? What material did you print it with?
JUSS10
I like Biplanes
Dan, I just posted the files to the Thingiverse group. The white frame I have pictured is what I posted. The orange one, the arms weren't strong enough and broke in a crash.
Orange was PET, white is PLA. I'll likely try one out of ABS as well.
JUSS10
I like Biplanes
Thanks SPONZ
I added a few more files. essentially there is a V2 frame and a V3 frame. You can mix and match the parts but essentially the V2 parts add specific location for the electronics. the arms have a spot for the esc to sit and wire routing, its just weaker than the V3 arm. V2 frame locates the FC in and allows for it to be "strapped" in place. the only down there is its a "rigid" mount to the frame then. This could add some vibration issues maybe? I'm flying with that frame plate now and it seems to be fine but I haven't tried the FC isolated so it come be that much better with foam tape. Just wanted to explain the different parts.
Justin
