MarcusHeap
If you got a Brushless cordless drill and removed the casing for weight, could you make it fly?
You have a high speed motor, speed controller, battery or two, charger and your set to go.
20v should give more umph, the batteries charge in 30 min and I recon with the lightness of the plane and the lack of resistance on the motor you could get a 30 min flight time.
The motor up front, BIG wings, 1/3 size tail to wing size, battery towards the mid to rear and could fly nice. Oh, and a Massive prop, 12 / 6 maybe?
$99 for an 20v cordless drill with two battery, with the size of the motor, ESC and batteries and charger could work out a lot less than buying branded gear.
Lowe's Home Improvement
DEWALT DCD777C2 - 797362
Attributes
Battery Amp Hours - 1.3
Battery Included - Yes
Battery Type - Lithium ion (Li-ion)
Battery Voltage - 20-volt max
Battery Warranty - 3-year limited
Brushless - Yes
Case Type - Soft
Charger Included - Yes
Forward and Reverse Switch Included - Yes
Maximum Speed (RPM)1600
Number of Batteries Included for Tool - 2
Number of Clutch Settings - 15
Sub-Brand--Tool Height (Inches) - 7
Tool Length (Inches) - 7.52
Tool Power Output - 340
UWOTool Warranty - 3-year limited
Tool Weight (lbs.) - 2.56
Tool Width (Inches)2.5
Variable Speed - Yes
Attributes
Brushless - Yes
Case Type - Soft
