jhmcdonald5th
Hello all. I actually don't fly planes. I am building an R2D2. I use the flysky FS-i6x as an RC controller for driving my droid. Channel 1 and 2 drive his feet (like a tank). Channel 3 (throttle) is unused. It's channel 4 that is giving me problems. Channel for is the horizontal movement of the left stick and it's what rotate's R2's head.
I have it hooked to a friction wheel. It's actually this product. https://www.graniteearth.com/ProductDetails.asp?ProductCode=Drive
So when I move channel 4 left, the wheel rotates one direction and his head spins. Since it's a DC motor, it's just positive and negative, so I can get his head to spin the other way when I go right.
The problem is this. I have to, for some unknown reason, put the subtrim in the menu options all the way in one direction and EVEN THEN, I have to use the little trim tab on the controller to push it a little more, just to keep him from rotating in either direction. Basically, the trim seems wildly off. I have no explanation for this. Is there a way other than the subtrim to calibrate a channel or a stick on this RC? Any suggestions other than what I've done (move the stick all the way over?) If I adjust endpoints, that doesn't help me, does it? What I really need it to adjust START points, but that's the trim and that's what I'm doing. It wouldn't be a big issue except that I don't have much more room to go, and if it gets worse, I won't be able to find any more trim?
Help me pilots. You're my only hope.
James
James
