messyhead
Hi folks. So as a safety feature, my tx won't switch on with any switches in an on position, and the throttle up.
I've been setting up a kill switch and failsafe today, and I noticed that the tx will switch on if the throttle is set to anywhere below the 2nd notch on the scale at the side of the control. See the video showing when it considers the throttle to be low enough. You can hear the motor start (prop removed).
Does anyone else with this tx have the same, or is it something in my setup?
I know that switching on the tx before the model will stop any inadvertent motor startups, but still seems like room for error. Especially as the tx can't be switched on with the kill switch enabled.
