Daniel DSouza
Hi everyone,
I’m having some trouble with a FlySky FS-i6X 2.4 GHz transmitter paired with an iA10B receiver, and I’m hoping someone here might be able to point me in the right direction. I’ve tried multiple times but haven’t been able to fully resolve the issue.
Hardware reference (for model clarity): FlySky FS-i6X 2.4 GHz transmitter
Issue details:
What I’ve already checked:
At this point I’m not sure if this is a binding procedure detail, firmware setting, or receiver power/initialization issue that I’m overlooking.
If anyone has experience with the FS-i6X / iA10B combo, I’d really appreciate:
Thanks in advance for your help. I’m still learning RC systems, so any guidance would be very helpful.
Issue details:
- Binding process sometimes completes, sometimes fails
- Receiver LED behavior is inconsistent after power-up
- Servos either don’t respond or respond intermittently
- Tried rebinding multiple times with throttle at minimum
- Tested with different power sources and servo connections
- AFHDS-2A mode is selected on the transmitter
- Model type and channel mapping look correct
- Failsafe has been reset
- No obvious wiring or power issues
- Common binding mistakes to watch out for
- Any recommended transmitter settings
- Known issues with this receiver and how to fix them
