Flysky fs-ia6 receiver
Coolhndluke
Hello,
My flysky receiver isn't showing any red light. I can't find anything online on where to check,what to check or anybody having this problem.It worked one day then the next nothing. Any help is appreciated. Thanks in advance.
Coolhndluke
No crashes, plugged in properly.
Plenty of charge on battery. It's not that old and only used it once. I take that back. I did wreck my F22 on its maiden flight but nothing serious I think. I haven't used it since and it's been a few months.
That is strange. Did anything come unplugged, maybe you flipped a plug when plugging back in. Any crashes?
Shurik-1960
If the receiver was in a model accident, then a crack in the board may occur or the legs of the chips may bounce off. Remove the plastic case and use a magnifying glass to view the entire board.But if you are an amateur in radio repair, take it to a phone repair specialist (along with the transmitter) and you will be happy.If you didn't like this advice, then: spit on the receiver 3 times, knock on wood, throw it far and for a long time...
Coolhndluke
Maybe it's yourESC, isn't giving power
So I got a new transmitter fs ia6b worked 1 time and now no red light.no power. Could my esc be bad and all of a sudden quit working then work again?
Or could there be a surge of sorts frying my receivers?
Shurik-1960
Check the voltage on the receiver plug when connecting your voltage regulator (end terminals)- it should be exactly 5 volts.Black wire = extreme and this is a minus.Take a photo of your controller connection to the receiver.
Coolhndluke
Thanks
It turned out to be a bad battery connector on the Esc. That would explain why it works then dont. I will fix it and be back in the air. Thanks everybody for the help.
