FOAM BOARD HJK SPEEDWING DISCUSSION
Zoom Master
Yeah.....It would be easier to see and control too.
and iv also fully decided on the setup ill be using ill first be using a iflight XING-E PRO 2207 2750KV motor with a 5x5 or 6x4 prop with a 6s lipo so yeah im pretty sure iv seen someone go 200 mph with a micro monster on this setup only dif was that they used a F80 pro which I might get if they are back in stock in time
Ummm. The 2750kv model is 4s.....You will burn up your motor if you run that for long at all....
Zoom Master
Still will be wild and I would do a SLOW trainer first....
wait a second hold up I just got a WILD IDEA.........my mini apex isn't to smaller then the lp 1.1 how about I slap a Peggy Pepper HK-2524-2410KV 8 pole on there I mean my fuselage is 465mm long and wing span is 600 mm I mean it isn't the craziest idea.......its so stupid it might just work....
no its actually 6s I checked
No it's 4S...I it's checked and I would post a picture if it would let me......I wonder if you are thinking of the 2050kv model....Here's the link , scroll down and click on data sheet and it will show the 2750kv model as 15v which is 4s.
Zoom Master
Nope, the 1900kv model is 6s, 2750 is 4s.
yeah but I dont really care anymore because after adding all the parts needed to my cart I have officially realized that it would actually be cheaper to build a apex phantom that can go 200 mph then it is to build a mini apex that will go 200 mph.......sooo yeah iv decided to screw the mini apex project for now as its just cheaper to build the bigger version ill share the setup im gonna use in a bit.
