FOAM BOARD HJK SPEEDWING DISCUSSION
L Edge
E sized, (D for maiden)
Are you aware that the D and E have the same max thrust , so if your weight is oversized, it won't lift off. My weight was 121.8 grams and you saw what mine did. You better take a video of yours. I found that my model has quite the velocity based on all the info. Trying to talk to Estes engineer and see if he agrees and can give me a gut feeling on height.
Yes I am, the E engines just have more burn time. And It won’t launch from ground, will be dropped from midair.|
L Edge
Been there, tried that. Way too dangerous, did shuttle(no engine) but the way that thing moves, it could kill someone. Yours being heavier, could be released and nose dive,flip? and head for the ground. Add speed say 300ft/sec plus straight down, not worth it.
It’s a delta wing, (v3 SpeedWing) and I’m gonna see if it’ll glide well first. If It’s a no-go, then I won’t do any powered tests.
