FOAM BOARD HJK SPEEDWING DISCUSSION
Zoom Master
Ramjet, Or maybe Pulsejet….
Issue with ramjet is that u cant find it anywhere if u want u gotta build one urself and Issue with pulse jet engine is that u also cant find one anywhere the ones I have found produce like 2kg thrust so it isn't powerful enough so im gonna use a massive solid rocket motor......
U asked chatgpt........our generation really is cooked........
Well I was already thinking that, I was just wondering if there were any other things we should take onto consideration besides what we were already....You would have to look it up on the internet and probable just read the AI answer OR I can just ask there and not have to go digging around on 100 sites just to find how thick you generally want...
Zoom Master
hmm I didn't see it that way I guess that is true
Here is a run down on your option by Chatgpt...
To hit 500+ mph in an RC aircraft, you’re well beyond normal EDFs or prop planes. You're in the realm of experimental, high-speed designs, and here are the most viable options:
🔥Best Options for 500+ MPH RC Flight:​
1. Rocket-Powered RC Plane
  • ✅ Fastest method — Easily exceeds 500 mph with the right design.
  • ✅ Lightweight and simple airframe
  • 🛑 One-shot flights unless using hybrid or reloadable motors.
  • 🛑 Limited control time — short burn, glide back or parachute recovery
Example: People have hit 550–600+ mph using rocket gliders and delta wings.
2. Turbine Jet Engine
  • ✅ Real jet engine — extremely powerful and realistic
  • **✅ Reliable throttle control unlike rockets
  • **🛑 Very expensive ($3K–$10K+)
  • **🛑 Complex to operate (kerosene, preheating, maintenance)
  • 🛑 Heavy — needs a large airframe to handle speed and fuel
Max realistic speed: ~400–500+ mph in streamlined setups
(But most turbine RC jets cruise around 200–300 mph)
3. Pusher Prop + Rocket Assist (Hybrid)
  • ✅ Electric or gas prop gets you in the air
  • ✅ Rocket ignites mid-flight to blast past 500 mph
  • 🛑 Complex ignition, safety issues, hard to test safely
Used in some world-record setups (e.g. slope-soaring rockets)
Not Feasible for 500 mph:​
  • EDF Jets — most max out ~200–250 mph, maybe 300 with extreme setups.
  • Ramjets — need to already be going fast; hard to ignite and maintain at RC scale.
  • Pulsejets — possible, but wildly inefficient and dangerous for controlled flight at 500 mph.
Summary:​
If your goal is record-breaking speed, then:
  • Rocket-powered delta wing is the best way to actually hit 500+ mph
  • Turbine jets can push 400–500 mph but are expensive and hard to fly
  • You’ll need excellent aerodynamics — low drag, high structural strength, and fast telemetry or tracking systems
