Kevinbennett126
6th December
** WARNING **
When I printed the Lancaster plans at 75% I did it "print-to-fit" on A4 paper.
As a check on sizes, the outer wing sections should be about 20" (510mm) long
Check you have this right or adjust the other measurements to suit.
In this thread ….
http://forum.flitetest.com/showthread.php?4374-foam-board-Lancaster-bomber
I talked about the foam board Lancaster that I built and a couple of people asked if I could share the plans, I don't have a complete set of drawings but its not that difficult to do so I've started this thread to explain how to do it.
I crashed my original Lanc so this is a chance to build another and share the experience with others.
This is not a beginners project, neither will it be a 'blow-by-blow' account of how to do it.
But if you've built one of the FT swappables before (especially something like the Spitfire with a folded leading edge ) and you have some idea of what your doing with a scalpel and glue gun, then it should be fairly straight forward to do.
I built the first one in a bit of a rush and with little confidence of it actually flying. But come the day when it was finished and the weather was calm enough, my friend and I decided to maiden it.
Because the final build is quite heavy, and the foam being fairly delicate we decided to run along with it on about half power and see if it felt like it might fly rather than risk a test glide.
We had the CofG in what we thought was about the right place and the thing seemed to balance ok, so John held it while I opened up the throttle. He started to run and almost straight away the thing was up and away.
Just glided out of his hands and into the sky – flew like a bird.
First couple of flights were a bit fast, I wasn't sure how slow it would fly or what the stall characteristics were like. But eventually slowed it down and was able to get a reasonably scale speed fly by.
So lets get started …..
First you need a set of Lancaster plans from this site ..
http://www.outerzone.co.uk/plan_details.asp?ID=2860
I printed these out at 75% - this gives a wing span of about 1400mm (55”
Also a copy of one of the FT plans and study the build video would be useful too.
I used the Spitfire build to work from because I could see how to do many of the Lanc parts and I'll be making reference to that here.
I started with the wing center section. This is simply a straight (i.e. no trailing edge curve) version of the main part of the Spitfire wing.
See Picture 1 for details, there's three score lines, one for the leading edge and two for the top of the wing 'curve'.
The wing spar is made up of two pieces of foam glued together – just like the Spitfire wing, so the slots need to be wide enough for two foam tabs.
Score the lines and fold over the leading edge as they do in the Spitfire video.
The foam board I use is not 'Dollar tree' and is tougher (probably 'Elmers' I guess) so I have to make a good job of creasing the leading edge fold to make it work without tearing the paper.
Cut out two center section spars as in Picture 2 and put all the above to one side for the time being.
For the outer wing sections, print out the wing plan from the PDF. Lay this on some foam board and draw round it - Picture 3
The nice thing about the Lancaster is it has straight leading & trailing edges which makes this all very easy, and this technique could be used for other planes with similar wing shapes.
Then add the score lines as in Picture 4 – don't forget to transfer the aileron from the plan too.
It should be obvious that it now includes the lower wing surface and cutouts for a spar.
You need two of these – one left & one right, I use the same paper pattern and turn it over (you only need the outline) that way it pretty much guarantees they will be the same size & shape, but do make sure you have the leading/trailing edges the right way round!
That's enough for now - more to follow later
** WARNING **
In this thread ….
