Jonny Gum
(GO TO PAGE 11 FOR PLANS AND BUILD VIDEO)
So I have always been around the real Stearman because my grandfather restores and flies them. I decided to make the Stearman because I had a balsa wood kit lying around for a rubber band powered model. I took the plans to Staples and got them scaled up to a 40 inch wingspan and built it. The fuselage uses a box surrounded by formers and outer skin to make a beautiful (completely foam board) fuselage. The wings use a new wingtip technique to make more realistic wingtips, and inside the wing is a box spar. This version only has ailerons on the bottom wing, just like the original, but still has plenty of aileron control. The paint scheme on the plane matches my grandfathers stearman- even the numbers on the side. All my plans are hand drawn but if anyone knows how to make online plans I would love to post them for everyone to use!
Note- I will bring this to Flite Fest Ohio 2019- See ya there!
Flight- This thing flies on rails! It flies amazing in calm weather, but gets bumped around a lot in the wind due to the second wing.
Specs- Power Pack B or C recommended, 40 inch wingspan, 4-5 sheets of foam to build, 9x6 wood prop is my favorite prop.
