Progress Update:
If you're building along after us,
@K3V0 mentioned the easy fix for the discrepancy in the plans. It can be accomplished in one of two ways. Either trim the bottom plate to match the wing, or trim the wing to match the bottom plate. If you've watched the build video, you probably saw where they apparently followed the second method. So that's what I did. I simply traced the angle of the bottom plate onto the wing, and cut it off at the blue line.
And below is where I have to end my build session for the evening.
I would have liked to have finished the hatch, but after nearly a month out of work, I am back tomorrow. I'm just out of time tonight. Hopefully I'll be able to build tomorrow night after work. I'll just have to wait and see how much oomph I've got left.
Still, progress has been good. All the servos are installed with pushrods and control horns. I even ironed the horizontal and vertical stabilizers to give them some rigidity. Other than the issue with the wing, there have been no real surprises with this build thus far. Forming the foam into curves is really simple and even satisfying, as the curve forms.
I'm off work next Tuesday and Wednesday, and the weather looks conducive to a maiden, if a little windy. Hopefully I'll have her ready to go!
