BATTLEAXE
That looks like a sharp plane. You did really well with all the new techniques like the forming and custom cutting. Looks like she will go fast.Looking good! I loved making the top hatch! I think it’s my favorite individual part for any FT plane yet 😸! The fit between the back bottom plate and the wing wasn’t too bad to fix. I felt it would be easier to replace the bottom plate than the wing if I messed it up. 😬 I’m glad you’re going back to work! It can be really hard to get back into the swing of things.
I’m curious as to the ironing. I’ve seen it mentioned a few times and some folks seem to use it on every project. The extra rigidity sounds nice. I assume you’re not using the household clothes iron 😆.
I had most of the plane built by Monday and I primed on Tuesday. I was able to get most of the paint done and have only a few touch up spots to work on. Yeah! This step adds days to the build but it’s also an extension of the building side. View attachment 148139 View attachment 148140
I put on the landing gear last night. I used a .78 diameter wire instead of then.10 that is used in the build video. It was easier to bend than my storch LG so I actually anticipate bent wires with hard landings. View attachment 148141
I also got the power pod installed and all electronics hooked up. I was exhausted by that point so I’ll adjust expo/rates tonight. I think I have to revisit my wire routing. I kinda just shoved everything inside from the battery hatch part and it could be cleaner. View attachment 148147
I wanted to use a different prop from my storch so I’ve put on a 9x 6. I know it’s more aggressive than recommend but it’s what I have. If this is a big no go, then let me know.
So, here she is! View attachment 148150 View attachment 148149
This was a involved but fun build! I think it went easier than the storch, but i think that plane set me up for better success here. I’m excited and terrified to maiden the mig and I want to thank the FT community for support and encouragement
I’ve been imagining all the other planes being built and readied for flight weekend and it makes me smile thinking I’ll be flying with all of you!
As far as the maiden goes, the 9x6 is perfect for this plane. anything smaller in pitch will almost make it seem under powered for the wing size and profile. 9x6 is my go to prop for any plane to maiden, if you want more speed later you could get away with an 8x8.
Ironed edges are something that offers so many benefits, I have tutorial vids on it here. Check it out and tell me what you think.
Again great looking plane and I wish you all the best on the maiden
