Hi all, I just need someone/s to confirm that I should use 6mm foam for the plane plan below.
RC Soarer Member Jan 29, 2020 #1 Jan 29, 2020 #1 Hi all, I just need someone/s to confirm that I should use 6mm foam for the plane plan below. Attachments BluCub2_full.pdf 22.3 KB Views: 0
SquirrelTail Legendary member Jan 29, 2020 #2 Jan 29, 2020 #2 RC Soarer said: Hi all, I just need someone/s to confirm that I should use 6mm foam for the plane plan below. Click to expand... Should work perfectly! Dollar store foam is close enough to the right thickness that it can be used
SquirrelTail Legendary member Jan 29, 2020 #4 Jan 29, 2020 #4 RC Soarer said: Ok, thanks! Click to expand... No problem!
