Hey guys recently I was trying to watch all of the episodes in one weekend (it didn't work out ;-() but anyways sand I saw the bricksler episode and I am avid fan of ultralights (fyi for anyone that doesn't know an ultralight is an plane that weighs less than 256 lbs and does not require a license to fly) and was thinking about buying a kit until I saw the bricksler episode and I thought would it be possible to essentially double it and create an ultralight aircraft (of course after flying it as an RC model first) so I did a bit more research and thought that the first thing that needed to be changed was the under camber airfoil and replaced by stacking up the 3/4 inch foam up into a block and cutting with a giant hot wire cutter. Of course instead of the foam fuselage I plan on replacing it with a a lawn chair for the cockpit and a 2x2 a4 aluminum tail. I highly doubt that ill ever fly in this but it sure is hell goin be fun doing fpv and scaring the hell out of the neighbors!!! Here is the link to the bricksler http://m.youtube.com/watch?v=bns5x4pvl5Y
And the link to the motors http://www.hobbyking.com/hobbyking/store/__22036__NTM_Prop_Drive_50_60_270KV_2400W.html
P.S. I am going to brace the wings with aluminum A4 tubes (every project I ever do somehow gets mixed up with A4 as I like to call it;-)
Thanks
Wjionieis
Thanks
Wjionieis
