Foam Wonder "Racer"
Foam Wonder "Racer" 1.0
Please log in to download
SP0NZ
FT CAD Gremlin
Admin
SP0NZ submitted a new resource:
Foam Wonder "Racer" - Foam Wonder "Racer" Free Build Plans
Foam Wonder
The "Racer"
Based on the original balsa wood design by Bruce Tharpe
Racer concept inspired by Tony Lewis
Foam Board Conversion by: Dan Sponholz
Plans by: Dan Sponholz
The Sig Wonder is a classic balsa wood and plywood, gas powered model that was designed by Bruce Tharpe in the early 90's and kitted by Sig Manufacturing. Many veteran modelers and RC pilots are familiar with this classic...
Read more about this resource...
Mr NCT
Thanks, @SP0NZ , this is a fun build. If it weren't so windy I'd be out flying it instead of writing this post :ROFLMAO::ROFLMAO:
Mr NCT
The weather surprised me this morning with the wind 3mph SE and 32°F. I built it to specs with the new shiny maker board but changed the battery hatch to a latch. With a 2300 3s battery I'm at 637g. It's a very nice predictable flier with no bad habits. I think I might increase the throws a little, maybe one hole on the servo arm. Thanks @SP0NZ !!
FlyingTyger
The ailerons on this one are a bit smaller due to the rounded wing. I am not surprised that it may need some more throw. Looks like it flies awesome!
Mr NCT
Thanks! Took all the servos from the 2nd to the 4th hole on the servo arm. Flies great, very responsive.
RCGEO
Any building suggestions? Built and fly the Ugly Wonder, Bloody
Baron, etc but this has different parts. Want to be sure I build it correctly....
Appreciated!
tomlogan1
Hi Sponz,
No pictures yet, but the build is very easy. I am particularly pleased with how the wing turned out. It is quite an improvement over the previous Flite Test designs. Thank you for providing this. The plans are so professionally produced. I compared these to the original Tiny Trainer plans (long time favorite) and wow what a difference. Again, thank you for making a quality design available to everyone.
tomlogan1
I'm into the fuselage and a few questions... There are "reference" marks on both the doublers and the fuselage itself I presume are for the fuselage former(s)? Remove the foam in the fuselage and cut through the doublers?
For the horizontal stabilizer, is it also glued back to the trailing edge of the wing, or just where the fuselage meets the cutouts in the stabilizer?
Hinges for the battery box? Just tape the hinge and use a magnet to secure the closure?
Beyond that a real pleasure to build.
Thanks.
tomlogan1
Apologies to Sponz...
But I had a ball doing it with a few changes.
No battery door because the wing is removable.
Different firewall so the motor is out in front.
Looking forward to the maiden.
2nd picture ~ all dressed up
RCGEO
Here is mine.....flies GREAT ! Wonderful design.
