Here are some of the supplies.
1.25mm JST connectors
Drywall fiberglass mesh tape
Heat shrink 3mm and 1"
PVC heat shrink 50mm. Pod cover.
2" blue foam sanded to pod shape and shrink pvc over. Also for a sanded nose that is hot glued to front.
.012 Beadalon 12 strand wire and 1mm crimps
.015" music wire
.039" music wire
Walmart transparent tape .75"×1300"
Duck brand clear packing tape
30ga silicone wire
Carbon tow 12k
4mm carbon flats
6mm carbon tube
Balsa tails 3/32" 4×36"
Plastic stock, credit cards
Popsicle stick for throw blade
Sand bag
Original gorilla glue
Hot glue and denatured alcohol to release glue
5 min epoxy
Beacon fabri tac or 3 in1 glue and acetone for thinner
Damp sponge
Metal yard stick
CA glue and accelerator
80 grit sand block
Dremel with cutting wheel
And thats not all. No wonder people would prefer to get an ARF rather than build their own
