Foamboard Grumman X-29 w/ 50mm EDF
finnen
Easiest way to check if it can handle 4S is to get a watt meter. The motor doesn't actually care very much what voltage it runs on, it's amps that kills it, but a higher voltage will make it draw more current as well. Measure the amps at 3S. If you are under the rated 27 amps you should be good to go with a 4S, and try with that. Keep in mind that it will draw less current in flight, than when testing static thrust. You could try to actually fly with a watt meter, to get an accurate reading of the max amps.
finnen
Oh, the ESC does care about 3S vs 4S. There could be components on there that won't be able to handle the higher voltage, so keep that in mind.
Centus
Im using the BLHeli ESC that come with the FT power pack C, that should be OK as long as I don't exceed 30A continuous right?
saiga556
Full of...
The ESC says 2s-4s on it. 4 call is good to go. I think that ESC has the capability of a 35A burst as well. Stuff a 4 cell in there.
