10tpeg
Hi there!
Im in South Africa, and plunged right in and bought 5 large sheets of 5mm foamboard. Then I built a Simple Scout as my first build, to become acquainted with the FT build tecniques. All went well, but the CG was WAY out, so after reading the forums, I designed an extension to the nose, and got it to balance perfectly. It flew like a brick! With full power, it flew ok but fast; but glided straight into the ground! When i weighed it it was about 80% heavier than the FT design.
Now I am left with 4.5 sheets of this board, and am trying to figure out what to do with it! I have weighed it and have found the following:
FT board 5mm = 290gsm
FoamX 5mm = 611gsm
I have peeled off the thick paper and weighed the foam - it is really light, but only can be used for formers, as it is flimsy. Rather than toss the board out, I want to use it. It occured to me to scale up the designs to decrease the wing loading.
Given the weight of the construction material, is there a formula that determines how much I should scale UP a design by?
FoamX 5mm = 611gsm
