The stuff I have is 206.6g per A1 sheet (594 x 841mm)
Just measured a Flite Test board for comparison and it's 111.6g / 20x30" (510 x 755mm as measured)
So the UK stuff I've been using is 413 gsm vs 290 gsm for the waterproof Flite Test board; which is some 42% heavier.
NB. I've recently been using
this seller on Ebay. Their boards are about as cheap as I can get them without having to buy huge quantities (pallet). I can also recommend them as one of my orders got bent double by the carrier and they happily replaced them with no fuss.
I'm with you there.
I've had good success marking out all the cut lines using a
slightly modified cheap vinyl cutter. The cutter's knife cuts through the top paper layer leaving a nice deep score line for a knife to follow (you don't even need a ruler).
With a fairly simple model (eg a Versa wing), using this method I can go from a blank foam board to being in the air in about an hour or so.
I also tend to scale up my models by 10% or so as the UK board I use is 5.4mm vs 4.8mm for Flite Test foam. This makes A&B folds fit much better and allows any tabs to fit together properly.
The extra size also makes some allowance for the additional weight of the denser & thicker foam.
The fact that A1 is pretty much exactly 10% larger in both dimensions than FT boards works out nicely as well.
Whereabouts in the UK are you?
If you're nearby I'd be happy to run some plans through the cutter for you.
