I have realized, over the last handful of years, I have managed to Design and build a Decent number of Planes.
I will use this pages to collect them all, and link the build logs.
One Sheet Wonders
■ Baby Bloody Widow P-61 |Plans V1.0 | Forum Thread
■ Baby Bloody Vampire |Plans B2.0 | Forum Thread
■ AF-X1 (Starfox)| Plans V1.0 | Forum Thread
■ Dragon Glider |Plans V1.0 | Forum Thread
■ Foamy Prandtl-D | Plans V1.0 | Forum Thread
■ Foamy Prandtl-D Arrow | Plans V1.0 | Forum Thread
FTFC18 WWII Design - Build Challenge
■ Moskelev Sam-7 "Sigma" | Plans B1.2 | Forum Thread (Plan v C1.0 Beta)
■ Kalinin K-12 | Plans V1.0 | Forum Thread
■ LPL Flying Submarine |Plans V1.0 | Forum Thread
FTFC19 - Fantasy Design - Build Challenge
■ Logan X-stream 6 | Plans B1.0 | Forum Thread
■ VF-9 (Robotech) | Plans B1.0 | Forum Thread
Crimson Skies
FTFC20 - Classic to Modern - Design Build Challenge
■ Foamy Bird of Time |Plans V1.0 | Forum Thread
■ Burgesse Dunne Flying Wing | Plan V1.0 | Forum Thread
■ Savoia Marchetti s55x | Plans V1.0 | Forum Thread
■ Lincoln Sport |Plans B1.0 | Forum Thread
■ Spruce Gosling |Plans V1.0 | Forum Thread
■ Foamy Mara | Plans V1.0 | Forum Thread
■ Foamy WindFreak | Plans V1.01 | Forum Thread
■ Minimoa 30 | Plans V1.0 | Forum Thread
■ Minimoa 50 | Plans V1.0 | Forum Thread
■ Skinimoa (18) | Plans V1.0 | Forum Thread
■ Remington-Brunelli v2 | Plans V1.0 | Forum Thread
■ Luscombe Silvaire | Plans B1.0 | Forum Thread
Big Builds - 80"+ Wingspan or (90mm+ jet)
■ Magician (DTFB Sorcerer) | Plans V1.1 | Forum Thread
■ IAR-99 SOIM (Hawk) | Plans V1.0 | Forum Thread
■ 84" Darkstar, SR-72 | Plans V1.0 | Forum Thread
■ 150" Ford Tri-Motor | Plans V1.0 | Forum Thread
■ 300% Noob Wonder |Plans V1.0 | Forum Thread
■ 192" (16') 400% Puri | Plans V1.0 | Forum Thread
FDM Magician Darkstar SR-72 300% Noob Wonder 400% Puri
OTHER
■ Synergy - Master Series | Plans V1.0 | Forum Thread
■Sky-Terror Sky Javelin| Plans V1.0 | Forum Thread
■ RC Foamy Game | Downloadable PDF | Forum Thread
■ S-3 Viking | Plans V1.0 | Forum Thread
■ EZ Viking S3b | Plans V1.1 | Forum Thread
■ Baby SR-71 | Plans V1.0 | Forum Thread
■ Micro Flying Flea | Plans V1.0 | Forum Thread
■ Foamy Modified Prandtl-D MS | Plans V1.1 | Forum Thread
■ Foamy Modified Prandtl-D FT | Plans V1.1 | Forum Thread
■ Foam Wonder - Noob* | Plans V1.1 | Forum Thread
■■ DTFB Puri | Plans V0.2 | Forum Thread
FDM Mod Prandlt-D MS DTFB Puri Foam Wonder - Noob Variant
*Design assisted a Variant of @SP0NZ Foam Wonder with @SP0NZ & @gooseigaly
Hayoa Miyazaki Inspirations
- Mehve |Plans V0.0 | Forum Thread
■ Tolmekian Bumblecrow|Plans vA1.0 | Forum Thread
■ Tolmekian Corvette|Plans vB1.0 | Forum Thread
■ Pejite Fighter|Plans V0.0 | Forum Thread
■ Tolmekian Cargo|Plans V0.0 | Forum Thread
■ Tolmekian Tanks |Plans V0.0 | Forum Thread
■ Totoro-drone|Plans V0.0 | Forum Thread
All my plans are done in full size sheets (ANSI-D 34" x 22"), You can still print them with a regular household printer. Select Print and your printer. select the "Poster" option in the "Page Sizing & Handling " section. Make sure to print 100% scale, overlap 0.005". Toggle on "Tile only large pages". PRINT away!
If you spot any errors please let me know and I will try to fix them.
Design Method for Clear Plans
I use AutoCAD Lt 2021.
My current design method. (mostly because Sketchup's flatten add-on feature didn't work for a while for me.)
Estimating model Weight. Knowing how many sheets is critical. Each sheet is 115g. on a typical layout approx. 75-65% of it is used. I go conservative at 75%, so ~85g/sheet Then I assume 1 Stick of glue 2 sheets. so that adds back ~24g. then you can look up the weights of the electronics, and Battery. A-Pack = ~100-130g, C-Pack = 300-350g.
Preferred Components
Servos - cheap blue 9g servos for most things, HMS 5g Servos seem to work well, otherwise 5g will be MG in the future
Control Horns - Aim Dollar Tree Dental picks. They glue well and the holes are perfect for the control rods.
Control rod - Landscaping flag wire. lengths for 18-21", at 10cents a piece. it beats $1/ft for the music wire. Rigid enough and works well with the Control horns.
Linkages - Z-Bends, Slack taken by a twist of the pliers.
Covering - Packing Tape - Colorful, cheap, and light weight.
Motors - Flite Test Radials are truly good quality and are the ones I lean on. however Emax is the other brand that seems to rarely fail me.
...To be Continued
One Sheet Wonders
Crimson Skies
OTHER
- I import the images... scale it so the fuse matches just larger than standard pod (2" for B or C, 1.25" for A) or match Prop sizes
- I draw over the image. P(oly)line mostly, Measure arc to confirm bent edges and flat lines should match up
- Then I offset, shift change the Linetypes/layers as appropriate (sometimes I do it right and put it in correctly first.) to account for the folds and think about where I want bend, tapers, or slight bends (like on the FT wing tops). Where ever the Top and bottom layers are a flat solid piece in my mind.
- Lt Blue Scores are for slight bends, like in the tail tapers, or paper removal edges.
- Red line grooves are for bigger more defined bends, or the edge of foam removal.
- Dots/Crosses/Concrete is for paper removal.
- Long Hatched lines are for long ironed or sanded tapers
- Short Hatched lines are bevels.
- DON'T FORGET to MARK CG's a hole. You can always dot with glue if it's right.
- When I'm happy, I try to make the outlines a single piece to facilitate moving it.
- Then I arrange it to be in the inner black box. (The size of a Adams ready board 29.5" x 20"). this is set in the standard FT sheet.
...To be Continued
