I hope everyone is safe and well in all the COVID chaos.
With the time indoors I finally found some time to complete all the little bits and pieces needed to finish the triplane. She's now ready for the maiden flight, but alas the field is essentially closed due to COVID. I'll post a video when I eventually get it in the air. Here's a few updates on the final work completed.
I installed the receiver and battery (5C 5000mah) in the fuselage, placing the battery as far forward as possible.
Next I tackled the CG question. The instructions in the kit are a little unclear in that the photo might be interpreted two ways (i.e. is it indicating the CG is 74mm from the leading edge of the middle wing or top wing?). I've concluded it's the middle wing, which also seems to align with my research on triplane CG, and that seems to be the consensus from others that bought the kit, but I'd be interested in any opinions on this. Here's the instructions image:
Next I installed the ESC in the motor box and started adding weight behind the motor to adjust the CG forward. I put metal plates inside the box (held with zip ties) and added lead stick-on weights as well. The goal was to make it a bit nose heavy for the initial flight just in case I've messed up the CG position.
Last but not least, I added some British "victory marks" beside the cockpit for some flair. Not really accurate for WWI I know, but hey why not? She's ready to go!
