Fokker Dr1 XL Plans
zpilot
I fell on my Fokker Dr1 XL and destroyed the LG, I do not want to purchase a kit for the foam board parts for the LG. Does any one have the drawings for this plane. I could not find them on the FT site. Thanks.
Mr NCT
VP of SPAM killing
Ouch, that hurts. I hate it when I do something like that - bang a wing tip on the door or drop a tool on a rudder. Sadly the DR1 plans have not been released yet. According to the latest podcast they should show up on the FTCA portal and then later they'll be available for purchase. The horse has already left the barn but always a good idea to trace the kit parts on posterboard for times like this.
zpilot
Thank you.
Foamforce
The landing gear has mostly foam pieces right? Here’s what I would recommend. Get a head gun from Harbor Freight and a small (~1”) putty knife. With those, you can disassemble the pieces carefully and trace them. Use the heat gun to heat up the end up the putty knife until it’s quite hot. The slowly slide the hot knife into the glued joints while lightly wiggling and pulling on the part. Reheat the knife often. You can also directly apply the heat gun to the joints themselves, but be gentle with it and avoid applying heat to and single layer parts like the stabilizers or control surfaces because they will warp pretty easily. Parts that have structure, such as the wing or fuselage, are much less likely to warp. Also, if you’re going to replace a part anyways, it doesn’t matter if it warps.
So start by carefully removing the landing gear using the hot knife technique to avoid damaging the rest of the plane. Once it’s off, use the heat gun to disassemble all the parts of the landing gear. Then trace the parts onto a new piece of foam board from Dollar Tree and cut with an Exacto knife.
Hope that helps.
zpilot
Hope that helps.
Thank you thats an idea i had not thought of.
Winginit
I just bought another kit and a stack of foam boards. Im going to trace a fleet of these planes and paint all different colors.
SP0NZ
FT CAD Gremlin
Admin
Oh man, that sucks! Sorry to hear that. I should have the plans completed and sent to Flite Test by the end of next week.
