Nice flight and build! Really, though? "Green Acres?" Where did you dredge that up from?! Nice blast from the past and a nice bird. Thank you for both.So far, I have the power pod and wing built, but didn't snap any photos in-process. Next time I get down to the dungeon to work on it, I'll take a few.
I plan on painting it the same yellow as the Waco, mostly because that's an easy color to see in flight.
In the meantime, here's the link to the maiden flight video of the Waco, which I had way too much fun customizing. I'm really happy with how the flying lines turned out.
Dynam Waco Maiden Flight
I foresee great and exciting things coming from you, @Hoomi.
I did mine with flaperons, and while they did slow it down, it flies super slow already. If you want even more stol capabilities than it already has (which it takes off in only a few feet already without the flaps), go ahead and program them in.I have never tried it before, but do you think that a scout would fly ok with flaps?
Wow I love it!!!Getting closer, though the maiden is going to be possibly delayed while I order a replacement servo for one of the ailerons. It seems to have a damaged gear inside, moves rough, and intermittently stops moving when it needs to. If it's acting up on the bench, it's darn sure not going in the sky.
I still need to properly mount the motor pod, which will include the motor facades on each side. I think that turtleback gave me more trouble than any other part of the build so far.
Please do!Looking good. I should post some pictures of my build too
