For testing purpose
French
Construire Voler S'écraser Répéter
#3
Using less battery cells (voltage) than rated just means the turbine will spin slower.
Using more battery cells than rated may mean fire.
Good luck with the testing
skymaster
Thanks guys appreciate the info. if it works ill start scratch building that x-29. let you know how it goes.
and ill need a 4s lipo. any sugestions edf is QF2827 70mm 12 Blades 2827-2849 2600KV , using a 70a esc .
skymaster
thanks for the link, that 3000mha 55c 4s does not look that bad.
or maybe
G5 50Cmax 4S 3300mAh 4.2V-Max LiPo.
all things are on hold until i test the motor.
skymaster
hey guys so i finally tested the edf and it's good. i tested it with a 3000mha 3s 40c and let me tell you i have a smaller edf and testing this thing was very intimidating the power on this thing and it was a 3s lipo will a 4s 3000 55c give out more thrust. i had started the scratch build on the x-29 its coming out nice what do you think?
2017-10-25 01.06.55.jpg 2017-10-25 01.07.26.jpg 2017-10-25 01.08.01.jpg 2017-10-25 01.08.20.jpg 2017-10-25 01.12.03.jpg 2017-10-25 01.12.44.jpg
