Foxtech gear?
hello again,
I was wondering if anyone has used the foxtech FPV gear? I wanted to know yall's experiences with the company. There prices seem right, but I cant find any solid reviews.
Thanks yall!
FlyingMonkey
Stuck in Sunny FL
Admin
#2
That's because it's budget equipment. From all of the reviews I've found it will do the job, but you're not getting performance out of it.
I'd still buy their gear, but I'm not trying to push miles into uncharted wilderness with my aircraft at this time. If I was flying more expensive gear, I'd want to make sure I had a more reliable video system.
#3
So it would be good if I wanna fly high rather farther out? I just want a casual set up, nothing too crazy, so I guess this would be the best bet so far :D
xuzme720
Dedicated foam bender
It probably will. You won't know for sure if there is interference where you are flying that might cause you problems, but that is true with any gear. Based on what you mentioned you should be fine unless there is too much radio/electronic noise where you fly.
FlyingMonkey
Stuck in Sunny FL
Admin
#6
As long as you're comfortable with it's limitations, then it should be fine.
I'd use it myself.
